Mark Shannon
- May 27, 2002
ok...I got a cabinet from Ikea, but it doesn't have very much ventilation (it has a glass door on the front), and I have many components on the shelves (CD player, DVD player, Reciever, VCR, PS2, Xbox, Cassette Deck).
I am worried about heat disapation or overheating, because after an hour and a half movie, my Panasonic SAHE100 is hot to the touch (it's hard to keep my hand on it for long).
Now, the reciever has a built in fan, but I would like something to get the air circulating in the cabinet... I had an idea to buy 2 or 3 of those mini 12V fans (the type you find cooling a computer processor), and a 12V adapter from Radioshack... I was going to splice the wire on the adapter, and connect the fans in series to the adapter (the reason for the adapter is so they can be run on AC power instead of batteries). After doing that I would drill appropriate sized hole in the back of the cabinet (it's that thin MDF type stuff) and mount them...
I have a couple questions...
1. What could I do to improve this (insulation from rattling, etc.)
2. Is the wiring going to be dificult?
3. Which way should the fans be pointing? Outwards to remove warm air, or inwards to bring in cool air from outside?
4. Is this an overall good idea?
Thank you in advance for your response...
PS, sorry if this is in the wrong section (this seemed like the best one..)
