Andy Olivera
- Jul 25, 2000
Using the meager knowledge from a C course I took 6+ years ago, I'm trying to write a small program that outputs an AVISynth script for decimating frames based on a specific pattern. I don't have the output in the correct order, yet, but that's not the problem. One loop seems to be getting ignored. The particular loop:
while(i < unique)
printf("nSequence:");
scanf("%d", &pattern);
i++;
I've tried using do/while and for loops as well, but I get the same result. I tried running the commands outside the loop and it worked fine(but it only runs once, obviously).
The whole couple dozen lines of code are here. I know it's probably something simple I'm missing, but I've looked over everything a dozen or so times and I don't see it. Any help would be appreciated.
while(i < unique)
i++;
