- Feb 8, 1999
- Robert Harris
These comments are not meant as a review, but rather as an open note to the technical gurus at Criterion in light of the release of An Anthology.
The concept of this DVD set goes back six or seven years, if not more, when with Stan's blessings, a discussion was begun with Criterion toward the production and release of a selection of Stan's work on laserdisc. Once the films were selected, and it became obvious that the set would run in the area of almost $200, with the necessity of many discs, the concept was set aside.
That Stan's work could be transitioned from projected film in a communal setting to the intimacy of a video monitor, and that he would be satisfied with the result was always in question. But when the concept of the project again moved to the front burner with the acceptance and success of DVDs, and Stan suggested that Fred Camper be his eyes and ears throughout the process, it took a major step toward actually occurring.
Working with Criterion, Fred was able to make the films work on video.
But one element always concerned me. And that was compression and authoring of films which were in many ways single frame works of art, connected and interconnected to form a motion picture which was much, much more than the sum of its parts.
This evening I finally have had the opportunity to screen samples of the final product, and to put it mildly -- I'm amazed.
My feeling was that the benchmark would be Mothlight, a film in which each and every frame is entirely different.
The end result?
You can now examine Stan's work frame by frame.
The image holds up to the digital mechanism.
Within this two disc set, one has the ability to watch and listen to Stan discuss his work.
You can also go to a track selected for each work and listen in on something that is much more than an interview; its a discussion between friends and collegues. Stan discusses his work with fellow professor Bruce Kawin. Kawin knows Stan and his work, so there is a great deal to be learned here.
That the video look as much like the film as it does is a tribute to the perseverence and support of Fred Camper.
He and Criterion have done Stan proud.
RAH
The end result?
RAH
