1. The HTF Tapatalk application has been discontinued. Please see the thread in the Forum Help & Feedback area for more information.
Buzzing sound from Sony KV 27 SF17......
Discussion in 'Archived Threads 2001-2004' started by Rich Gio, Jan 9, 2002.
  1. Rich Gio
    Rich Gio Extra
    Jan 7, 2002
    16
    I plugged in my TV and was suprised to hear a distinctly audible "Hum" coming from the back of the TV. After letting it run for awhile the Hum diminished,but never fully disappeared. Anyone else experience this? Faulty set perhaps? I pressed mute and that had no effect on the "hum" so it's not a sound/speaker/interference problem. The Hum changes pitch as the video image changes. Lighter background images appear to produce the loudest hum.
  2. Jeffrey Noel
    Jeffrey Noel Screenwriter
    Sep 11, 2001
    1,533
    Rich, I know that sound! My good friend has a 27" Sony Wega(or is it Vega?) that makes that annoying little sound. He's taken it back to Circuit City twice, and they were not able to fix it either time. They said they had no clue what was making the noise! Awhile ago, someone had posted this exact problem, and others had it too. I guess it's just those damn TVs.
    Maybe you should contact Sony directly and find out what the hell is causing that noise. If you do, let us know!
    Best of luck!
  3. Rich Gio
    Rich Gio Extra
    Jan 7, 2002
    16
    Man, the TV is UNWATCHABLE! I called PC Richards and they said they will swap it out with a new one. I'll give it one more try.If the new one makes that sound I'll buy the Toshiba AF61.
  4. Rich Gio
    Rich Gio Extra
    Jan 7, 2002
    16
    AHA! I figured out what was making that "buzzing sound"!
    I had the TV plugged into a surge protecter,a REALLY old one! When I plugged it directly into the wall the set became quiet as a mouse. Must be some weird harmonics from the surge protector/power strip.
  5. Kevin Simon
    Kevin Simon Extra
    Dec 23, 2001
    22
    OK. I too just bought a KV-27FV17. I too am experiencing this buzz. Unberable at plug in, it is dimminishing even a day later. However, mine is plugged into a quite new Monstercable Power--Strip, so I doubt that is the issue. Could it just be from all the shipping...that things just need to get "settled in" a bit?
