buzzing amp
Discussion in 'Archived Threads 2001-2004' started by Eric P, Jan 19, 2003.
  1. Eric P
    Eric P Auditioning
    Nov 26, 2002
    4
    I have a Carver 705x amp that I pulled out of the closet the other day to hook up. I had buzzing coming from all speakers except the front right. I unpugged everything except the amp and still had the buzzing sound but ever so slightly less. After hooking everything back up, the slight change in volume of the buzz is from the tv being off and on. One other thing is that amp uses a two pronged plug - not three. The sound from the speakers can also be heard by listening closely to the amplifier's transformer. My other amplifier has no problem. Is there something inside that needs to be replaced or fixed? Could be problem with my house electricity? Any help or suggestions would be aprreciated.
  2. Jason Co
    Jason Co Second Unit
    May 24, 2002
    366
    Eric-
    Do a search on ground loop.
    J
  3. Chu Gai
    Chu Gai Lead Actor
    Jun 29, 2001
    7,270
    perhaps consider running a wire from the chassis of the amp to the ground on the outlet.
