Robb Roy
- Jul 15, 2002
I purchased a new Parasound 1500A this weekend, and immediately noticed a buzzing noise coming from the speakers. Unhooked the cable, dss, etc. (all the gear attached to the HTS2500), with no change in the buzz. I did find a lamp in the same room (our main source of light, actually) that is halogen with dimmers, and the buzz goes up and down in volume with the brightness of the lamp. With the lamp unplugged, there is still a slight buzz.
Now it gets interesting, I think. Sounds like a ground loop problem, so I buy a cheater plug to test the theory (I know this is only a short term solution). I have everything hooked up to a Monster HTS2500. When I plug the amp into the other socket of the same outlet as the HTS2500 (with the cheater plug), there is absolutely no buzz, no matter what I do with the lamp. If I plug into that same socket without the cheater it behaves exactly the same as I had it in the HTS2500. If I plug in the amp with the cheater into the HTS2500, the buzz is back, but is not affected by the lamp!
So, I guess this long explanation comes down to 2 questions: 1) Do people think getting a dedicated circuit to my system will help? 2) Any other ideas/theories I'm missing?
Thank you all in advance for any ideas you have!
-Robb Roy
-Robb Roy
