Buying new amp, concerned about speaker max input power
Discussion in 'Archived Threads 2001-2004' started by Mike_Mig, Mar 1, 2002.
  1. Mike_Mig
    Mike_Mig Stunt Coordinator
    Jan 17, 2002
    59
    I think I have decided that I want a Sunfire Cinema Grand which is rated at 200 Wx5 with all channels driven. I have Paradigm studio series speakers, 100's, 20's, and center. My concern is that the specs for the 20's say suitable amplifier range is 15-150w, and the center is 15-175w. There is also a maximum power input value listed which is 100w for the 20's and 130w for the center. So I am wondering if the Cinema Grand would be overkill wasted power or just damage the speakers. If this is the case I would consider the Sunfire Stereo Amp for just the 100's, which wouldn't be sunch a bad choice either. All input is welcome.
    Mike
  2. John Garcia
    Jun 24, 1999
    11,571
    25
    NorCal
    Should be no problem at all. The amp is not going to deliver 200w continuously, unless you turn it all the way up.
  3. John Tompkins
    John Tompkins Supporting Actor
    Aug 30, 2000
    660
    Mike, your speakers will have no trouble with the sunfires watts, provided you dont turn the volume up to max[​IMG]
    Actually its the other way around. With a less powerful amp it will reach its limit and distort quicker causing possible damamge to you speakers. With a more powerful amp you dont have to worry about this.
    Can you use the power, hell ya[​IMG] It really depends on what the sensitivity of your speakers are as to how much of a difference you might actually hear. Maybe somebody who knows the sensitivity ratings of those particular speakers can answer that part of your question..hope this helps
  4. Evan S
    Evan S Cinematographer
    Nov 21, 2001
    2,210
    Studio 20's are rated at 89db.
    Buy the Sunfire. Trust me...your music/HT will never sound better. I have a 200WPC amp hooked up to mine with no problem whatsoever. Like they said, unless you go all the way with the volume the speaker will handle the watts with ease.
  5. Kevin. W
    Kevin. W Screenwriter
    Oct 27, 1999
    1,534
    Mike,
    At one meter away from the speakers if your sensitivity is 89db:
    1watt: 89db
    2watt: 92db
    4watt: 95db
    8watt: 98db
    16watt: 101db
    32watt: 104db
    64watt: 107db
    128watt: 110db
    Unless you listen at extremely high volume levels you should hit reference(105db) with only 64watts
    Kevin
  6. Lee-c
    Lee-c Second Unit
    Sep 2, 2000
    497
    Kevin. W: There's one important factor you didn't mention. Distance. I forget what the exact formula
    is, but for every extra yard you back away from the speakers after the first yard, you need more power
    to get to reference level volume at your listening position.
    Perhaps someone who knows what affect distance from the speakers has on volume can post
    the formula.
  7. Kevin. W
    Oct 27, 1999
    1,534
  8. Michael R Price
    Michael R Price Screenwriter
    Jul 22, 2001
    1,591
    You lose 6 dB for each doubling of distance. (Decibel loss = 20*log(1/distance[meters]). So, if you sit 3 meters (10 feet) from your speakers you'll lose about 9 dB. But then there's also boundary gain (reflected sound from your room) which will add something like 2-4 dB especially if you sit far away from the speakers and/or near walls. So I'd say your overall sensitivity is something like 83 dB at the listening position, meaning you might be running into peaks of over 100 watts at reference level.
    Either way, you're definitely not in danger. I'm sure the Paradigms can handle plenty of clean power, especially the 100s (the center and surrounds don't get as much power anyways. Especially if you run them small which you should.) And with 200 watts you're unlikely to clip the amp. So go ahead, I'm sure that setup will rock.
