Peter.LeBlond
- Jun 4, 2002
Ok, here it goes. I'm gonna buy my dealer's Piano Plus HE-3100 demo unit. I'm calling this morning to double check and make sure that I'm going to get the full manfacture's warrantee and stuff, but if so, I'm gonna go pick it up this afternoon. Just wanted to ask a couple last minute questions. If you can answer any of them for me, I'd greatly appreciate it.
1) Burn in. DLP can't burn in right? So I'll be safe playing many hours of XBOX on it?
2) Do DLP chips ever get "stuck mirrors"? I know that LCD can have pixels go bad or get stuck. Is this an issue with DLP?
What issues are there as far as wear and tear go? I know that the bulb has a life expectancy of ~1000 hours, but is there anything else that I should either look for or protect against to ensure that my Piano has a long and happy life?
Also, what do you guys think of the deal I'm getting? The unit sells new for $2699 new, and I'm getting it for $2300 plus tax ($2461). The unit probably hasn't been used much, as he does even have it installed usually, I had to call and have him break it out of the box. I'm going to check the timer the unit keeps on how long it has been run...what should I expect, what number of hours would be too high?
Thanks for all the help you guys have been.
Pete
Pete
