Jim_C
- Feb 6, 2001
>>Hmmm, interesting on the Panasonic. I've got to say that the name scares me. I wouldn't have considered them before
You've probably already thought of this but have you considered cracking the battery case open and looking for replacement batteries at Radio Shack?Hey, cool idea. I hadn't thought of that. Might be a fun project...
have you considered cracking the battery case open and looking for replacement batteries at Radio Shack?Be careful!!!
Electrical components actually run on smoke. If you let the smoke out they won't work any more.
-j
The Li-ion systems are awesome. I would definitely recommend an upgrade, if it fits your plans. Unfortunately I think you've probably missed some great deals by a few months. Many of manufacturers just brought "new" models to market and that led to closeouts on the "old" stuff. Keep in mind the differences were negligible and in a lot of cases just cosmetic. Maybe there are a few of these deals still around.
I was still using my 12 volt Dewalt until last summer. I bought one of the smaller impact drivers by Bosch that was li-ion. It has been awesome and I also got a free driver with it. These 10.8 or 12 volt systems worked better than my Dewalt and my friend's old Rigid 14 volt for most stuff, but they don't have a chuck. After seeing my drivers in action, my buddy bought one of Makita's competing models.
I didn't really need a new drill, but a couple of months ago I started noticing great deals on 18 volt li-ion drills. I actually ended up getting a four tool combo set for about $100 less than some of the drills were going for. The drill that was the impetuous for the purchase was a Milwaukee V18 that has some similarities to the one you linked. I love it.
What's the model number on your drill?
0824-20
I checked it out. CPOMilwaukee is selling it for $180 and Amazon for $79. Both are drill only, no battery. What a price difference.
What is a hammer drill, anyway?
What is a hammer drill, anyway?Hammer drills do not spin continuously like a basic drill. They spin the bit until a certain torque threshold is reached and then transitions to a hammering action. The driver will then spin the bit in short bursts with extremely high amounts of torque (i.e. 2k ftlbs vs 300ftlbs of a normal drill). These units are exceptional at driving screws and lag bolts (MUCH better than a normal drill) and tend to be more comfortable for these applications. Larger hammer drills are often called rotary hammers and actually produce a down/up hammering action (similar to a jackhammer) as the bit spins. These are used for drilling through masonry or rock and are large and heavy (not recommended for driving screws). Hammer drills meant for driving screws do not use a normal chuck that you'd see on a drill (i.e. you can't use normal drill bits) but rather bits with a notch on the end (you've probably seen them before).
