Rob_J
- Aug 4, 2001
I tried burning a VCD to a CD-R to see if it would play on my Toshiba SD1600. I've heard the player is compatible with VCDs. The CD-R did not work, the player showed "Disc Error" on the display. I did some more research and found out that the player needs CD-RW, so I burned it again onto a re-writable disc. The same error occurred.
I'm not sure if it is a formating problem with the disc, I used Nero and followed a proven method, or if the player cannot play VCDs at all.
Has anyone else tried this, or heard of these issues before? It would be nice to burn some Simpsons episodes or download the first two episodes of Star Trek Enterprise that I missed
Thanks for any info!
