Burned out amp LED - how does it work
Discussion in 'Archived Threads 2001-2004' started by Bill Kane, Nov 6, 2001.
  1. Bill Kane
    Bill Kane Screenwriter
    Feb 5, 2001
    1,359
    The LED (LCD?) panel light quit on my old (early '80s) Technics SA-949 stereo 65-watt amp/tuner. My closest Panasonic repair center (70 miles) wont say if a part is available unless I take it in and they break it open.
    Is an LED like a generic bulb - insert and it's repaired - or may there be circuitry involved?
    I may be looking at $50 here and a long drive, and I wonder if it's worth it, since I have taken this out of my system, but may give it to a friend to power his TV cable/audio output.
    bill
  2. Saurav
    Saurav Cinematographer
    Feb 15, 2001
    2,174
    Well, is it LED or LCD? LCD stands for Liquid Crystal Display, like the numbers on a cheap digital quartz wristwatch or a digital clock radio. LCD displays usually form letters and/or characters. LED is Light Emitting Diode, the little red or green lights that tell you that an amplifier is powered on, which input is selected, and things like that. While someone could construct a number display out of LEDs too, that would be rare.
    Anyway, if it's an LCD display, there's almost certainly circuitry involved. If it's a single LED that needs to be replaced, you could probably just solder a new one in, as long as you pick an LED that matches the one that was in there (in terms of current/voltage/etc.).
    And finally, maybe you're just talking about a regular bulb that's used in old radios to light up the tuning dial? If that's what has blown, that would probably be just a little bulb that you could screw in, again, once you find teh right replacement.
  3. Bill Kane
    Feb 5, 2001
    1,359
    Saurav, it seems to be LCD in that the numbers (e.g. FM frequencies) still appear on the glass panel. It's the background illumination that's gone. IIRC, the display was black on white. I suppose it'll have to be inspected....
  4. Kevin P
    Kevin P Screenwriter
    Jan 18, 1999
    1,439
    It sounds to me from your description that it's a LCD display backlit with a small bulb. That bulb is burned out so it doesn't light up, but in bright enough light you can still read the display, right?
    A lot of times those tiny bulbs are soldered in, but if you're good at soldering you could get a bulb at Radio Shack (check the voltage before buying a bulb) and put it in yourself.
    KJP
