Burn In Question
Discussion in 'Displays' started by CalvinCarr, Jan 31, 2004.
Thread Status:
Not open for further replies.
  1. CalvinCarr
    CalvinCarr Supporting Actor
    Dec 4, 2003
    512
    I am still researching the 60XBR950. I watch a lot of ESPN and was wondering if the Bottom Line will burn in the screen if watched too much?
  2. ChrisWiggles
    ChrisWiggles Producer
    Aug 19, 2002
    4,791
    Please read through the Master Burn-in thread, which is stickied at the top of this forum. You can access it here:
    http://www.hometheaterforum.com/htfo...hreadid=105385
    I will summarize, but certainly read the thread and/or post in it with your questions:
    If you calibrate properly, which includes drastically lowering the white level of your set, you very significantly reduce the chance of burn-in.
  3. David Parrish
    David Parrish Stunt Coordinator
    Jan 24, 2004
    128
    The 60" XBR has no burn-in according to the Sony webpage:
    "• No Phosphor Burning "
    Of course, this could be a play on words(The XBR has no phosphors to burn in), but everything I've read says LCD technology is safe for steady image programming and PC use.
  4. ChrisWiggles
    Aug 19, 2002
    4,791
    Well, of course since I was too lazy to look up what kind of TV that was, I assumed it was CRT. Since it's LCD, that pretty much answers your question!
    [​IMG]
Thread Status:
