Brian Bunge
- Sep 11, 2000
The resistors are there in order to get the load back to 8 ohms. Although impedance is frequency dependent so just because you measure 8 ohms at 1KHz doesn't mean you'll measure 8 ohms at 50Hz. If you wire up the 3 drivers in parallel you'll have a nominal 2.66 ohm load and will likely fry your amplifier. You really need a crossover specifically designed for the drivers which you plan on using.
