eppo
- Dec 28, 2010
- Joe
This area is going to be in the basement, and about half of the side of the house. the stairs come down the middle and split the basement in two. on the right side i plan to have a bar and set up a home theater. one thing i'm conserned about is room size and shape, should i enclose a rectangle shape room to put my Home Theater in, and put the bar outside, essentially creating two rooms on that side? should i just leave it the way it is, and put the bar on the side where the stairs come down, and home theater on the opposite side?
Then, as far as equipment goes, how much is too much to spend on a receiver? i've been reading around and i would think that the units that are in the $500 range should be good, possibly the [SIZE= 14px]ONKYO TX-NR708 7.2-Channel Receiver, it seems to have more functions than i could ever use. for the speakers, i am not really sure whats good, whats a good price range to couple with this receiver. i was thinking i would do 5.1, i did read something about 7.1 needs a certain room type, but not sure what type of room would work well with a 7.1. i would like to mount some of my components in the wall, probably the TV and the center speaker. from what i have read the optimum placement for the right and left front speakers is off to either side of the center, but equidistant to the viewing position. would i be best off with the floor standing speakers?[/SIZE]
[SIZE= 14px]if the budget allows, i'm going to go for a 3D HDTV in the 50" range. i'm going to use this set up to mostly watch bluray movies played on my PS3, and some gaming. right now i only have the PS3, i was thinking about adding a WII or 360.[/SIZE]
[SIZE= 14px]any help you can give me to point me in the right direction would be great. i'm not looking to be spoon fed info, any documentation i can read to get me started is welcomed also.[/SIZE]
[SIZE= 14px]in the end i want to make sure that my money is well spent, and that i will enjoy plenty of hours in my man cave![/SIZE]
[SIZE= 14px]thanks[/SIZE]
[SIZE= 14px]Joe[/SIZE]
