Building riser platforms for movie seats, or, "When lag bolts become machine screws"
Discussion in 'Archived Threads 2001-2004' started by David Tolsky, Mar 30, 2001.
  1. David Tolsky
    David Tolsky Supporting Actor
    Sep 3, 1999
    638
    I thought I would attempt to share my experience of building my riser platforms for my 3 rows of cinema seats in the dedicated room. The size of the room is basically the size of a 3-car garage. In fact, it sits right on top of one. Of course, when building platforms on a second story floor, there will be no foundation underneath the plywood, but rather a whole lot of air. I decided to use 2 x 6's as the strength of the platform. Where to lay the boards on edge across the floor plywood was determined by laying out a row of seats and marking where the "legs" were to be bolted down. I used very sturdy L brackets with half inch bolts to secure the 2 x 6's in place. After laying out the boards on edge and securing them, it was just a matter of attaching new plywood over the tops for the platform. The seats would get bolted through this new plywood right into the studs (2 x 6's). This plywood would later be covered with carpet pad and then carpet.
    Okay, so what about the first row of seats? They are bolted right to the floor/plywood and certainly not all the posts are going to be bolted into studs under the floor. I was hoping to get lucky and just bolt right into floor board and be done with it. That came back to haunt me. A few sittings and up came the bolts and the seats were not secure. So how do I secure the seat posts? Went to O.S.H. and talked to a guy. He showed me this carded tin foil stuff called "Mr. Grip". It's supposed to tighten the grip of the bolts. I actually bought some of this stuff and brought it home before realizing how ridiculous it was. Then it hit me, Threaded inserts! I would buy these brass threaded inserts with 1/4" threads inside and use 1/4" machine screws instead of bolts. Amazingly enough, after digging around, O.S.H. actually had some (.59 a piece). Well it worked like a charm and the seat posts are secure.
    If you're planning on securing some real cinema seats to an upper floor room, these are some things you may want to consider.
  2. Joseph Hoetzl
    Nov 28, 2000
    36
    Did you have access to the bottom side of the floor via the garage? You could have also put t-nuts (I think that is what they are called...) on the bottom side, and then bolted into that.
    Cheesy T-nut diagram in case I named it wrong:
    It is basically a cylinder with a washer type thing attached to it, with little nail-points that grab the wood and get pulled into it by tightening the bolt
    HAT (Hoetzl's Apartment Theater) Pics are up!
  3. Ron-P
    Ron-P Producer
    Jul 25, 2000
    6,284
    7
    Ron
    For my rear deck, I used 2x12s doubled up at 16" OC. Then I used 2 sheets of 3/4" plywood for the top. It is a stand alone deck and I wanted it to be heavy and durable so it would not move. Also, having the doubled up 2x12s and 1.5" of plywood, placement of the chairs was not an issue. I used 2" lag bolts with lock washers and they do not move.
    For the front row, I attached a 2x12 to the front of the back deck using 1/2" galvanized pipe and some -L- brackets. I used 1.5" lag bolts for those chairs. Everything is very solid. I probably over built it, but I did not want any problems.
    Peace Out~ [​IMG]
    [​IMG] The Green Room
