Bruce White
- Dec 5, 2001
- Bruce
OK, I believe I'm only a few weeks away from actually setting up my HT. In June of 2001, we began an addition to our home. I bought my speakers about 2 months into the project and still haven't hooked them up yet! I'll be installing the flooring in the new room that will have my HT and now I need to figure out what cables/connections I need.
I did in-wall wiring for the rear surrounds using 12 ga. wire as recommended in various HT groups. My speakers are Paradigm Atoms for the rear, Mini-monitors for the front, CC-370 for the center, and PSB-12 for the sub.
How do I hook up these speakers to my receiver? What kind of connectors do I need? What do I run from my receiver to the wall outlet leading to my rear surrounds and what do I run on the other end between the rears and the wall outlets?
My receiver is an Integra 5.2. My DVD player is a Panasonic RP91. My VCR is an older Phillips, so ignore. My TV is currently a cheap Phillips, but soon to be replaced by a Mitsubishi 55809 or 55819.
What kind of cables/connectors do I need for connecting the receiver, DVD, VCR, and TV together? What do I connect to what?
I've heard/read that building your own cables is less expensive than purchasing them and that they work just as well. Feel free to correct me on that, if necessary.
I'm looking for build advice or purchase advice.
All help will be greatly appreciated! Thank you!
Bruce
Bruce
