northman
- Nov 6, 2008
- greg
Hi all, thought I'd start in the basics forum and see how things go. I am building a home theater with a projector, looking at the new Panasonic AE3000, but waiting a bit to see if Epson comes out with anything better. I will initially project onto the wall to play with screen dimensions, and then buy or build a screen to suit the preferred format, whether it turns out to be 16:9 or 2.35 or whatever. I have room to run the image out to the projector's (reasonable) limits, so picture quality is an issue.
I already have a Denon AV receiver that should put out some good, clean power, but it is a couple years old and does not have HDMI inputs.
I have been getting my TV over the air with a regular antenna, which is about to end.
I like the idea of having a DVR with a hardrive to record shows like Tivo, but without the monthly service. Philips makes the DVDR 3576H/37 which does this, and also includes a ATSC tuner to pick up broadcast digital TV.
For best DVD playback I will get a Blu Ray player, but I may not get that right away if the Philips DVR does a respectable job.
So to the questions:
What is the best way to preserve video quality using the receiver without HDMI inputs? I'm guessing I could run HDMI directly from the Blu ray Player to the projector and use separate audio connections, does that introduce any compromises compared to the more normal practice of routing everything through the receiver? At least I'm guessing I would not have any on-screen indication when changing volume, is that correct?
Should I do the same with the DVR output? Or is that not as critical?
If the digital broadcast TV thing turns out to be crap I may end up going to cable, does that change anything?
Hope the post wasn't to long, I wanted to give a little perspective to the issues at hand. Thanks for the help.
Greg
Greg
