Wayne_j
- Nov 7, 2006
- Wayne
Currently my theater room doesn't have a standard TV so I need to run my projector any time I watch or listen to anything so I decided to build a small 2 channel system so I can listen to music without having to burn away hours on my lamp.
So far I decided on:
TEAC CD-P650 CD player with ipod interface.
Amazon product
Micca Origain amplifier.
Amazon product
Klipsch RP600M speakers.
www.klipsch.com
Those speakers are incredibly well rated. The current price of $439/pair is much lower than the $600 I have seen them for in the past. I'm not sure about the amp but it should be able to adequately power the highly efficient speakers. If I need better I can swap it with the 'emotiva' amp I currently have running my surrounds.
Amazon product
Amazon product
RP-600M Bookshelf Speakers | Klipsch
Using legendary technology, the RP-600M bookshelf speakers delivers incredible acoustics to fill your home with loud, crystal-clear sound and robust bass.
