building a crossover for infinity component set (car)
Discussion in 'Home Theater Projects' started by Brian Pokosh, Dec 5, 2003.
  1. Brian Pokosh
    Brian Pokosh Agent
    Nov 9, 2003
    32
    I had the crossovers for my Infinity Perfect 6.1s stolen from my car over a year ago and want to get these back in use. I've check the spec sheet from Infinity and this is all I found on the crossovers:
    Crossover Frequency: 3.5kHz, 24dB/oct.
    Linquitz-Riley Acoustic
    Can anyone point me in the right direction? I did call Infinity early this year and they wanted something like $100 to replace them.
  2. Chris Tsutsui
    Chris Tsutsui Screenwriter
    Feb 1, 2002
    1,865
    I think your best bet will be to find somebody with the crossover and find out what components values are in it so u can make your own.
    You'll probably need 4 caps, 2 inductors, and 2 resistors (from looking at the pic) for each crossover which will run you about $40 in parts. What's hard is finding the inductor value and DC resistance which is supposed to have an impact on the sound.
    Although... perhaps a simple "textbook" crossover will give you satisying results. I find that car environments mainly ask for loud and balanced sound. You could do a search for a crossover calculator such as loudspeakers101.com and get values for a 4th order L-R crossover.
