Build your own LCD projectior
Discussion in 'Archived Threads 2001-2004' started by NathanP, Aug 26, 2001.
  1. NathanP
    NathanP Supporting Actor
    Aug 13, 2001
    841
    Have any of you guys or gals tried the thing where you buy a 2" lcd display and put it in a slide projector?
    Does anyone suggest doing it?
    How do I do this?
    Any tips?
    Thanks!
    Nathan
  2. NateF
    NateF Stunt Coordinator
    Aug 22, 2001
    63
    Umm.. I think that's pretty much beyond the realm of something you can build yourself. I mean, you have to translate the video signal coming in into telling the LCD what color to make pixel #46748... not an easy job.
    -Nate
  3. Neil Joseph
    Neil Joseph Lead Actor
    Jan 16, 1998
    8,332
    Neil Joseph
  4. Allan Jayne
    Allan Jayne Cinematographer
    Nov 1, 1998
    2,404
    Do you mean the 2 inch directly viewed backlit display in one of those coat pocket battery operated TV's?
    1. The resolution of those things is far far less than 480 scan lines by even 240 [email protected]:3, the projected picture would be terribly grainy.
    2. The heat from a slide projector lamp will probably destroy the LCD unit, assuming you can get it outside of the TV unit and into the projector where a slide would go.
    3. I am led to believe that the contrast would be quite poor.
    By the way they make (or used to make) an LCD panel I think about 7 by 10 inches, which you put on an "overhead" projector. I don't remember whether it was computer VGA only or whether it displayed NTSC video.
    Other video hints: http://members.aol.com/ajaynejr/video.htm
    [Edited last by Allan Jayne on August 27, 2001 at 08:25 PM]
    [Edited last by Allan Jayne on August 28, 2001 at 07:20 AM]
  5. NathanP
    Aug 13, 2001
    841
    Hmmm...
    I've heard alot about this subject and that there are ways to solve the heat problem...
    Anyone else done anything like this?
    Nathan
