Bugger. Looks like the Sony DVD burner is on it's way out
Discussion in 'Computers' started by Rob Gillespie, Apr 26, 2004.
  1. Rob Gillespie
    Rob Gillespie Producer
    Aug 17, 1998
    3,632
    5
    Over the weekend my DRU-10W which I've had since last February has failed whilst burining DVD-R disks. I've tried two differnt Riteks, a Prodisc and an Optodisc dye-based blank and all have failed at different points. What's weird is that it seems OK on DVD-RW and +RW as well as CD blanks.
    The Nero log file from one of the failures is:
  2. John Watson
    John Watson Screenwriter
    Jul 14, 2002
    1,937
    You're waaay more computer literate than I (I've seen your posts for a long time Rob), so there's no way I can help you.
    Computer's self-diagnosis is rarely helpful, the last cd failure I had Nero said "General protection Fault", might as well have told me I got out of bed on the wrong side. [​IMG]
    If you sent that report to Ahead, would they be able to tell you anything (in the unlikely event a human being looked at it)?
    Anyway, good luck!
  3. Rob Gillespie
    Aug 17, 1998
    3,632
    5
    I tried another -RW last night and it failed within minutes.
    Oh well, good job I've got a Pioneer A07 on it's way :)
  4. Patrick Sun
    Patrick Sun Studio Mogul
    Jun 30, 1999
    38,761
    485
    9,110
    So how many DVDs did you manage to burn with this unit before it gave up the ghost?
  5. Rob Gillespie
    Aug 17, 1998
    3,632
    5
    Not sure. A few hundred, maybe. Probably no more than 500 maximum.
    That'll probably be the last Sony kit I buy.
  6. Max Leung
    Max Leung Producer
    Sep 6, 2000
    4,611
    I'm not familiar with that burner...is it external or internal? SCSI or IDE or Firewire or USB?
    Maybe you have a bad cable connection? Or perhaps an as-yet undetected virus or spyware is interfering with the burn?
    But then again...500 DVD burns...wow. Probably killed the laser (burnt out!).
    I hope my DRU500 doesn't bite the dust...of course I only burned 30 or 40 discs. Bring on the dual-layer burners!
  7. Rob Gillespie
    Aug 17, 1998
    3,632
    5
    It's actually a DW-U10A which was the internal OEM version of the DRU-500. When I say 500 discs I'm talking absolute maximum and it's probably a lot less than that. Either way, it's too short a life span for a burner.
  8. DaveGTP
    DaveGTP Cinematographer
    Jul 24, 2002
    2,096
    Other things you could try : try replacing the IDE cable, make sure there isn't some new firmware floating around for your drive. Just a couple of random thoughts - I've seen some weird things from failed IDE cables.
  9. Rob Gillespie
    Aug 17, 1998
    3,632
    5
    Done all that. Even tried moving it to another machine.
    It's fecked.
  10. brentl
    brentl Cinematographer
    May 7, 1999
    2,921
    110
    Seems like the Sony burners tend to blow up pretty quickly.
    I'm just happy that they're cheap enough that I won't worry if I can only burn 200 discs before it implodes
    $100 for a burner so you figure 50 cents a burn for 200 discs.
    Brent
  11. Max Leung
    Max Leung Producer
    Sep 6, 2000
    4,611
    gah...I paid $600 CDN for my burner. Eeek I can't believe I did that...
