Budget Screen (1 Viewer)
Matt Weldy
I am looking for a budget screen. I will be pairing it probably with the optoma hd70 (720p). And screen paint is not an issue becasue I dont have the paitence and I hate to even paint a wall. Any help would be appreciated. The selling point to my wife was I can get a projector and screen for the price of a big screen and the picture be twice as big.
Chad Isaacs
Check out eastporters.com make sure to select us or canada at the top of the screen ( 2 little flags) they have some great prices and according to reviews at avs, great screens as well.
ChrisWiggles
blackout cloth as suggested is a good basic choice for smaller screens.
the highpower fabric if you want to go big and bright is also excellent and you can get that pretty cheap from dalite if you get the commercial stuff which is the same thing but less expensive.
Also, see the screens forum at AVS.
tcbkf
