Budget Home Theater?
Discussion in 'Archived Threads 2001-2004' started by Brent_N, Nov 21, 2001.
  1. Brent_N
    Brent_N Stunt Coordinator
    Jul 30, 2001
    61
    I am sure there are many of us who cannot afford to spend (or justify spending) an unlimited amount of money on the top of the line components for home theater, but at the same time want to assemble a quality home theater on a budget. Maybe it would be helpful to have a dedicated "Good Home Theater for Cheap" type forum.
    From reading through previous threads, here is the system I am currently planning. Any comments, or changes you would consider?
    • HDTV: Toshiba 53HX71 (4:3 makes the most sense for me. I'm not looking to debate this).
    • Progressive Scan DVD: Panasonic RP56
    • STB: Samsung SIR-T150 (only interested in OTA HD at this time).
    • Receiver: Onkyo TX-DS494
    • Main Speakers: Paradigm Mini Mk-3 (I already own these).
    • Center: Paradigm CC-170
    • Surrounds: ??? My situation will require in-wall or in-ceiling surrounds. Any ideas?
  2. JerryW
    JerryW Supporting Actor
    Feb 7, 2001
    640
    Budget?? Nice budget. [​IMG]
    I's go up to the Onkyo 595 (if it were my choice) but that would be it. Looks like good picks to me.
  3. KeithH
    KeithH Lead Actor
    Mar 28, 2000
    9,413
    Brent, you have a nice list of budget components there. While I do not purport to be an expert on in-wall or in-ceiling speakers, I have heard a lot of good things about Niles products. Crutchfield sells them, and I believe Tweeter does as well. Whether or not they will match up well with your Paradigm speakers is another story.
  4. Aaron H
    Aaron H Supporting Actor
    Jun 28, 2001
    592
    Paradigm makes in-walls, which will most likely be the closest match to your already existing Paradigm L/R/C.
    Aaron
  5. Sean Conklin
    Sean Conklin Screenwriter
    Oct 30, 2000
    1,720
    I'll second the Paradigm in walls.
    And your plan looks good, maybe try to move up to the Onkyo 595.
  6. Chuck C
    Chuck C Cinematographer
    Jan 6, 2001
    2,224
    I also suggest moving up to the 595.
