Check out Samsung at Best Buy. Sam's Club also has the Samsung set under the Akai brand & it can be had for around $350. The Samsung set is black & the Akai is silver if that makes any difference to you. Do a search on both the Akai & Samsung & you will find plenty of info on both of them. Hope this helps you out.
