Jedd
- Feb 5, 2002
I tried to do everything as cheap as possible and here what I got:
Materials:
- Shiva 12" driver
- tube 12"x48"
- MDF 24"x24" cutted on four pieces 12"x12"
- plastic pipe 0.5"x92" cutted on two pieces 0.5x46"
- polyfill 3 pounds
- "piece of finish" 12"x12"
- sock for the tube
- grill
- wires&connectors
A - tube
B - MDF bottom endcap 12" radius, 1" thick, have a hole for the wires
C - MDF bottom stand 12"x12" (the only part you need to finish ), 1" thick, have a hole and bottom routing for the wires
D - 46" support struts, made of pvc pipe or wood
E - MDF ring, 11" inner radius, 12" outer radius (the hard part), 1" thick
Assembling:
- glue B into A, - fill A with a fiber, - glue D into A, - glue E into A (screw/glue to D), - screw driver to E, - put a sock on A, glue C to B, screw a grill to E, adjust wires and seal the hole in C
But it's all just a theory. I have no idea (yet), how to make a 1/2" MDF ring and how stable this whole structure will be.
Any comments?
Materials:
- Shiva 12" driver
- tube 12"x48"
- polyfill 3 pounds
- sock for the tube
- grill
- wires&connectors
A - tube
Assembling:
Any comments?
