BTV picture quality
Discussion in 'Computers' started by Steve Weeks, Aug 1, 2005.
  1. Steve Weeks
    Steve Weeks Stunt Coordinator
    Jul 12, 2002
    58
    When I record shows at the highest quality setting (~3GB/hour,) the quality is still pretty grainy. I notice this mostly while watching sporting events, but it is present in all my recordings.
    I am using an ATI AIW video card for the video capture. Would a hardware encoding card, such as a Hauppauge, help with the picture quality?
  2. ChristopherDAC
    ChristopherDAC Producer
    Feb 18, 2004
    3,729
    Short answer: not likely.
    Try a better antenna first, but you have to understand that broadcast NTSC has its limits, and the broadcast NTSC you usually get does not come near pushing those limits. Signal/noise ratio, colour, resolution and so forth are rarely going to be much better than VHS; if you want to see how your card is really performing, try a high-quality analog source such as LaserDisc. Anyway, having used both the AIW and the tuner-compressor-only "eHome Wonder" [effectively the same as the Hauppage] I definitely recommend the former. My suggestion would be to try changing your CODEC and other settings, such as the "video soap" noise reducer, and see if that makes a difference.
  3. Steve Weeks
    Jul 12, 2002
    58
    How would I change the CODEC or adjust the video soap?
  4. ChristopherDAC
    Feb 18, 2004
    3,729
    Try starting the "ATi Multimedia Center": open TV, go to "Setup" [the box with the check-mark in it at the bottom of the Control Panel], to the "Personal Video Recorder" tab, and hit "Map Preset" to get a list of available recording modes and options for making your own.
