Bryston 4b with preamp
Discussion in 'AV Receivers' started by AlexKunec, Sep 21, 2003.
  1. AlexKunec
    AlexKunec Stunt Coordinator
    Mar 9, 2002
    161
    i recently bought a bryston 4b nrb i dont have a preamp yet. I hooked my soundcard (m-audio revolution 7.1) directly to my amp. When my soundcard is turned up all the way (there is no volume control on the bryston) the amp isnt putting out nearly what it is capable of. I asked a friend if i needed a preamp and he said the a preamp will only attenuate the signal, so it wouldnt help. What do u guys think?
    Im running adire he 10.1s off it.
  2. Allen Ross
    Allen Ross Supporting Actor
    Sep 30, 2002
    819
    the pre amp should bump up the signal, from line in to a useable level for the pre-amp, do you know if there is a sensitivity control on the amp? or some jumpers that you have to solder? i had to do that with my crown and now it is plenty loud with just line in. but i will have to remove them when i get my Crown IC 150 (should be in monday) [​IMG]
  3. Dan Pawlowski
    Dan Pawlowski Stunt Coordinator
    Aug 12, 2002
    100
    Sound cards usually put out "line level". Bryston 4bs have two gain controls on the front. A mini flat head screw driver will work to adjust them.
  4. AlexKunec
    Mar 9, 2002
    161
    There is no gain control on the front. This is the bryston 4b nrb and was manufactured 10 years ago.
