Bryston 3B and B&W 602 S2 Overkill?
Discussion in 'Archived Threads 2001-2004' started by Jerry T, Nov 22, 2001.
  1. Jerry T
    Jerry T Agent
    Jul 11, 1999
    37
    Just picked up a used Bryston 3B 2channel [email protected] to drive my B&W602s2 as fronts.
    Is this overkill? Or should I trade it in for a Rotel Amp. instead. Like the RB-1070, RB-1080, RB-1090, RMB-1066 or the RMB-1075?
    And how much do you think I can get for the Bryston?
    Jerry
  2. Pete Jennings
    Pete Jennings Second Unit
    Sep 13, 1999
    333
    I heard a similar setup a few weeks ago, although I am not sure of the Bryston amp model #. WOW! Those 602/S2's really sounded great with the Bryston!! I could not believe the imaging and detail out of a $600 pair of speakers! I went home with a big smile on my face, because I could just imagine my 602/S2's at home combo'd with that amp. I wouldn't hesitate to pair the two up. As far as being overkill, who's to say you won't upgrade your 602's sometime down the road to a higher model B&W? You would be kicking yourself then for passing it up.
    If I had a shot at a used Bryston for a good price, I wouldn't hesitate.
    Go for it.
    Pete
  3. Jerry T
    Jerry T Agent
    Jul 11, 1999
    37
    Thanks Pete!
    Think I'll keep the Bryston.
    I just might upgrade my speakers.
    Jerry
  4. rodneyH
    rodneyH Supporting Actor
    May 22, 2001
    844
    Whem I origionally bought my old 602s, they had a very expensive Theta hooked up, they sounded great.
    Plus when you upgrade your speakers- you will already have a great amp.
  5. Greg_W
    Greg_W Stunt Coordinator
    Jul 6, 2001
    54
    I'm running my B&W 601's with a Bryston 9B and I would not go back. The Bryston is somethingI will be able to keep in my system for a long time through many upgrades. Congrats on your purchase.[​IMG]
    Greg
