Geno
- Oct 1, 2001
what do you prefer?
Transparent amp, neutral speakers.Thats easier said than done. First how do you know transparent sound unless you have been to the orignal mastering and know how it sounds right out of the horse's mouth, so to speak? I find most amps and speakers color the sound either way and ultimately its the proper speaker/amp mating that gives us the most satisfactory sound.
Those were not choices given.That's because I think outside the box!
OK, I guess to better answer your question, I'd go for bright speakers and warm amp. But I really think you should also consider the pre-amp in the equation.
Martin.
