Bridging & Sub Connection
Discussion in 'Archived Threads 2001-2004' started by Stasulos, Oct 5, 2002.
  1. Stasulos
    Stasulos Stunt Coordinator
    Sep 9, 2002
    50
    I've got a sub-amplifier that has high voltage stereo inputs, but no outputs. Can I connect it in a following way: connect sub to L&R front outputs on the receiver and connect L&R front speakers to the same outputs on the receiver? If not, what is the best way to connect the stuff?
    Question 2: I've got another alternative for the amplifier - a stereo amplifier. If I connect it the same way as above and then just bridge the fron L&R to the sub, will that make my two front channels effectively one? Will I loose the stereo there?
  2. Lee Petty
    Lee Petty Stunt Coordinator
    Jun 1, 2002
    204
    i think if you try bridging a stereo amp (not a car audio amp) you will probably fry it.
    home theater receivers and such are usually only designed to handle a certain load, per output.
  3. Wayne A. Pflughaupt
    Aug 5, 1999
    6,130
    40
    6,610
    Katy, TX
    Wayne
    Stasulos,
    Your post makes no sense – perhaps that’s why you aren’t getting much help here. For instance:
  4. John Garcia
    Jun 24, 1999
    11,571
    25
    NorCal
  5. Robert Sun
    Robert Sun Agent
    Aug 24, 2002
    40
    Stasulos,
    I have a Sound Dynamics RTS 1000 powered subwoofer that also has only speaker level inputs but no outputs also. I connect it up to my reciever in the way you described. Run speaker wire from the front L&R outputs in the receiver to the high level inputs into the subwoofer. I found that it blends better this way. My crossover is set to 60 and the amp speaker size to Large mains.
