Breakout Cable
Discussion in 'Beginners, General Questions' started by Ramon O. Valera, Oct 29, 2003.
  1. Ramon O. Valera
    Ramon O. Valera Stunt Coordinator
    Sep 10, 2001
    64
    What exactly is a breakout cable?
    -Ramon
  2. Glenn Overholt
    Glenn Overholt Producer
    Mar 24, 1999
    4,203
    A simple explanation would be a group of wires bound together (like with wire ties) where you could 'break' one of the strands 'out' and connect it to something.
    Glenn
  3. Eric Samonte
    Eric Samonte Screenwriter
    Mar 31, 1999
    1,318
    A breakout cable to be used to connect a component out player to a VGA port for say an X1. Use only the red, green and blue BNCs but u will also need BNC to RCA adapters.
    [​IMG]
  4. Ramon O. Valera
    Sep 10, 2001
    64
    Thanks!
  5. ChrisWiggles
    ChrisWiggles Producer
    Aug 19, 2002
    4,791
    "A breakout cable to be used to connect a component out player to a VGA port for say an X1. Use only the red, green and blue BNCs but u will also need BNC to RCA adapters. "
    Ehh... i don't think so...
    A breakout cable, as far as i am familiar with it, is used to connect a computer to a projector with RGB ins. A computer VGA connector contains all 5 connection pins, and most projectors have 5 separate BNC plugs, so they just terminate the other end with BNC instead of VGA plug.
    You can't send component video to RGB ins.
