Break in speaker frequency?
Discussion in 'Home Theater Projects' started by Ryan Leemhuis, May 18, 2005.
  1. Ryan Leemhuis
    Ryan Leemhuis Second Unit
    Oct 1, 2002
    490
    Can someone suggest a good frequency to break in a 6" driver with? My book says a sine wave of 25Hz but I don't know if that sounds like a good idea to me.
  2. Mike_Bauer
    Mike_Bauer Extra
    Jul 8, 2002
    17
    easy way is just to play FM, even noise from between stations. Or set up a cd changer for repeats
  3. Ryan Leemhuis
    Oct 1, 2002
    490
    NOTE: These speakers are not built yet so I cannot play FM. I am looking to break them in before doing measurements on them.
  4. Dan Wesnor
    Dan Wesnor Second Unit
    Apr 28, 1999
    389
    Just hook them up to an amp and play something through them, make sure the volume is turned down so they don't beat themselves to death.
    If you want to get the most break-in for the power output, play a tone at Fs. But it's really not critical what you use, you just want to flex the spider and surround.
