MikeNic
- Jun 17, 2006
- mike nicolella
Hi all,
I just got my brand spankin new 46" Bravia XBR3 yesterday - it's great! The only 'HD' source I have currently is my Xbox360 and 720p clips that I can download from Xbox Live. I played around for awhile, plus played some games and everything is simply stunning!
Then I had an idea - get a DVI -> HDMI adapter, throw my PC into 1920x1080, and I get to see 1080p. Well, I did all of that and the TV recognizes the 1080p signal and everything is well except I am seeing some strange artifacts on the display - it is most easily seen with text, in particular dark/black text on a non-white background, I can see pixels that are vertically adjacent to the dark pixels appear brighter than they should - when viewed from a distance it looks rather ugly. I have been playing with the color settings on both the TV and the PC all day now and I can't figure out what the problem could be. I found the 'advanced' section in the picture settings on the TV and turned off all of the 'edge enhancement' et al. to no avail. At work I remember someone tried to connect one of the sony rear-projection sxrd displays to the PC via DVI->HDMI and got basically the same result. Has anyone seen this before, and have any kind of tips / solution? Anything I should do/try to help pinpoint what the problem might be? I tried putting the PC in different resolutions and they all have the same problem in varying degrees... Would be most grateful to anyone that can help!
I have a Radeon 9600XT video card that has a DVI output on the back...
