BRAND NEW Klipsch LF-10 subwoofer $500 DC
Discussion in 'Archived Threads 2001-2004' started by Frank Carter, Jun 23, 2002.
  1. Frank Carter
    Frank Carter Screenwriter
    Mar 12, 2002
    1,187
    Brand new in box Klipsch LF-10 subwoofer for $500 plus S&H. If you are around the DC area, demo it before you buy and save on the shipping. Item was opened only for testing and sounds great!
    This is a great musical sub if you're trying to save space and still have great bass.
    You can check out my ebay feedback rating under ebay seller name: FABULOUSFRANKIE
    SPECIFICATIONS
    FREQUENCY RESPONSE: 19Hz-100Hz±3dB
    MAXIMUM ACOUSTIC OUTPUT: 120dB SPL @ 1/8 space, 1 meter
    ENCLOSURE TYPE: Bass reflex via dual passive radiators
    AMPLIFIER: BASH® digital hybrid
    AMPLIFIER POWER: 700 watts maximum continuous (1650 watts peak)
    AUTO POWER ON: 2 second ON delay, 15 minute OFF delay
    LOW PASS CROSSOVER: Continuously variable from 40-120Hz, 36dB/octave slope above 120Hz
    INPUTS: 2) Line level RCA phono jacks, 1) Line level dedicated LFE (unfiltered) RCA phono jack and 2) High level speaker terminals
    OUTPUTS: 2) Line level RCA phono jacks and 2) High level speaker terminals
    PHASE: Switchable 0 or 180 degrees
    DRIVE COMPONENTS: Subwoofer system using one 10" (25.4cm) front-firing, kevlar / fiber-composite cone woofer and two 10" (25.4cm) side-firing, kevlar / fiber-composite cone passive radiators
    SUBWOOFER: K-1073-K 10" (25.4cm) Kevlar / Fiber-composite cone / cast aluminum frame active / Two KD-104-K 10" (25.4cm) Kevlar / Fiber-composite cone passive radiators
    DIMENSIONS (H x W x D): 14.2" (36cm) x 13.6" (34.5cm) x 15.4" (39.1cm)
    WEIGHT: 49 lbs. (22.3kg)
    ENCLOSURE MATERIAL: Medium density fiberboard construction (MDF)
    FINISHES: Matte-finish Black vinyl
  2. Frank Carter
    Mar 12, 2002
    1,187
    Price is now $500 shipped.
    I'll also include the invoice I received so you'll have a valid warranty through Klipsch.
