Brand New! Audiosource monoblock 5.1A
Discussion in 'Hardware Classifieds' started by DorianBryant, Feb 11, 2006.
  1. DorianBryant
    DorianBryant Screenwriter
    Apr 14, 2004
    1,555
    This is brand new and never used! An audioSource monoblock amplifier. Check out the specs..
    The Amp 5.1 stereo power amplifier from AudioSource is a powerful and flexible addition to your home theater. You can use this monoblock amplifier by itself, or combine it with a series of Amp 5.1 units to power an entire home theater and drive speakers throughout your home.
    The clean design houses a high-power amplifier that is easy to set up and easy to expand as your home theater grows. AudioSource amplifiers deliver accurate, rich sound, combining high sound-pressure levels and a clear reproduction of even the most subtle details of sound. The Amp 5.1 provides up to 100 watts per channel with total harmonic distortion of less than 0.1%.
    Depending on your needs, you can place and replace several monoblock amps in one system. It’s easy to connect power sources, audio and video inputs, and speaker outputs with the expansion-friendly design. Balanced inputs allow the Amp 5.1 to connect to audio and video components with XLR outputs, and unbalanced inputs handle RCA output connections.
    The front panel of the amplifier has a simple array of LED displays that signal both operating status and potential warnings. A protect warning helps you avoid overloading or overheating the unit, and it will reset the unit to the initial settings once the problem is addressed.
    A phase control button allows you to switch the polarity of the speaker outputs to compensate for occasions where speakers are out of phase and sounding hollow. A low-cut control feature filters the lowest frequencies from your small speakers, preventing distortion and protecting the speakers. In the heart of the amp, the torodial power transformer generates a big sound while reducing distortion by shielding the sound from stray magnetic fields. You can control the volume directly on the unit or by adjusting the signal source component (such as your receiver, preamp, etc.).
    What's in the Box
    Amp 5.1 stereo amplifier and owne'rs manual.
    Product Description
    A 100 watt monoblock power amplifier that gives you pure high end sound at a great price Low cut switch filters out bass below 100Hz with a 12dB slope Also features front panel status LEDs, level control, heavy-duty gold-plated five-way binding posts on the back panel, & much more Whether driving a single passive subwoofer or a dozen pairs of in-wall speakers, this amplifier is the perfect solution
    This NEW and UNUSED amp for $80 and shipping...
  2. DorianBryant
    Apr 14, 2004
    1,555
    Rob,
    There is no message??
  3. DorianBryant
    Apr 14, 2004
    1,555
    Price drop to $75 and shipping. These sell new for $110 at etronics...
  4. DorianBryant
    Apr 14, 2004
    1,555
    65 and shipping...
