Methos
- Sep 4, 2006
- Edward
I need to redo my setup due to losing my office to a new child.
Current Setup:
My desktop is my DVR. I get my signals from an HD antenna. I record to the harddrive, edit videos, then connect to my MVIX by USB (due to transfer time only). USB goes through the wall as the computer is against the same wall as my entertainment center in the living room. I do have WIFI set up at home already.
Moving the computer out of this room leaves me with very few choices that I can come up with. First thought is to run more wires. I don't really want even more plugs in the walls and running the wires poses other problems of even being able to do it.
I considered getting rid of the desktop for a laptop. BUT, my computer has a teraflop of hard drive space and I need it on at all times to record when needed. So the desktop is still needed.
One consideration is using a small plain computer with an external hard drive that I can hook up and try to hide in the entertainment center. Remove the hard drive, hook up to the lap top and edit videos and rehook to MVIX yadda, yadda.
There is also the issue of setting the XP Media center on this small computer when not having the computer connected to a key board, a mouse or a monitor poses problems. I could set it up for WIFI and use my VPN to connect but again, I think I may have other issues in this plan.
Any other suggestions that people have would be great!
Thanks for reading
Eddie
Current Setup:
Thanks for reading
Eddie
