BP 1803 LT system?
Discussion in 'Archived Threads 2001-2004' started by JimPeitersen, Jan 17, 2002.
  1. JimPeitersen
    JimPeitersen Second Unit
    Dec 7, 2001
    470
    I tried to look through the past threads about this specific project, but couldn't find much. Has anyone modeled the 1803 in a small (relatively) sealed enclosure? I have an 1803 on order, and a Mackie 1400 planned for driving it. Obviously I would need something like a BFD. My modeling program (Bass Box Pro) isn't helping very much. Thanks for any input.
    JP
  2. Brian Bunge
    Brian Bunge Producer
    Sep 11, 2000
    3,716
    Jim,
    You could get by with around 4-5ft^3 and use the BFD to boost the low end as well as eq out any humps in the response. This is probably what I will do instead of the LT circuit. Just using the BFD allows you to tailor the response specifically to your room. You can do the same thing with the LT circuit but would be much more time consuming. You'd have to build the circuit, measure the response, then alter the circuit if you wanted to change the response.
    Brian
