Box building what kind of joints
Discussion in 'Archived Threads 2001-2004' started by Bob Bartlett, Jun 28, 2002.
  1. Bob Bartlett
    Bob Bartlett Stunt Coordinator
    Jun 28, 2001
    209
    I'm going to be building some speaker boxes this weekend and wanted to see what kind of joints most of you are using. Has anyone done mitre joints? I'd like to know the plus and minuses about different joints.
  2. Rob Lloyd
    Rob Lloyd Stunt Coordinator
    Mar 22, 2001
    234
    I use butt joints as I think most others do as well. It's much easier to cut a square joint. I just spread glue and then use a brad nailer to save time over clamping.
    Dados can also work for things like braces making assembly easier if it holds it in place better.
    Let us know how it turns out.
    Rob
  3. Brian Bunge
    Brian Bunge Producer
    Sep 11, 2000
    3,716
    I use butt joints on the exterior and use dados for braces in the A/V-1+'s.
    Brian
  4. Chris Tsutsui
    Chris Tsutsui Screenwriter
    Feb 1, 2002
    1,865
    My site has some pictures of how a contractor and I lock mitred the joints.
    The sides are all angled into a trapezoid type enclosure so the lock mitre helped a lot.
    We used standard carpenters "yellow" glue and heavy duty C clamps to hold it in place as seen in one of the pics. We would have used the standard clamps but there were too many angles.
    It makes a very strong and not to mention super air tight joint, however it can be difficult without the proper setup. I believe it took about an hour or two just to setup the machine that makes them. Afterwords we squished the edges and added maple edge tape to the bottom.
    I would do it only if you use pre-laminate mdf, it probably won't be worth the trouble if you're just going to veneer or paint it. It may look easy, but it requires some decent wood working skills.
  5. Chris Carswell
    Chris Carswell Supporting Actor
    Mar 5, 2002
    598
    I would stick to good old but joints. I do the same as Rob, glue then brad's. I'm not worried about the nails b/c I use wood fill to cover the small holes then sand, prime, sand, paint, wet sand, and clear coat [​IMG] Unless you have good skills and great tools (12" Compound Miter saw, adj. table saw, & high hp/rpm router) I would stay away from the other stuff.
  6. Gary Joe
    Gary Joe Stunt Coordinator
    Dec 6, 2001
    74
    still working on my SCH kit but got all of the cuts made. The instructions ask for miters on all edges, so that's what i did. It all fits together tight as a puzzle too. It took a while without a dado blade, but I want to take my time and do it right the first time. So that's one for dado's, but i'm a newby.
  7. Mark_E_Smith
    Mark_E_Smith Second Unit
    Jan 10, 2002
    275
    I used butt joints with "biscuits". if you have axcess to a biscuit jointer it really makes a strong joint. Check your saw to make sure you have 90 deg, I cut my fist pass with 2 deg off 90 :b . Also check you mitre for 90 to the blade or make a sliding table out of 1/2 plywood and some oak(esp if you are going to build a lot of paanels). That makes sure you have right angles on your panels.
  8. Bob Bartlett
    Jun 28, 2001
    209
    I think I'll give the mitre a shot. My father in law has a mitre saw not to mention a whole woodworking shop and said it should be no problem. I'll try a couple of pieces and if it doesn't work go back to good ole butt joints. Biscuits is a nice idea also. Thanks for everyones help
    Bob
  9. John_Lee
    John_Lee Supporting Actor
    Mar 31, 2000
    966
    Has anyone done mortise and tenon joinery with the side pieces accepting full-blind tenons from the top, bottom, front and back? That is my intent. I know precision will be a key and with my equipment shouldn't be a problem. Is it worth the extra effort?
  10. Mark_E_Smith
    Jan 10, 2002
    275
    I assume you will be using MDF? I think the goal is a leak free joint rather than a super strong joint. I choose biscuits to help align the panels and I didnt want to use screws.
  11. Dave Poehlman
    Dave Poehlman Producer
    Mar 8, 2000
    3,813
    I used butt joints held with wood glue and screws... but only because I have limited woodworking tools/skills.
    If I could, I would rabbet (sp?) the joints to make assembly easier.
  12. Hank Frankenberg
    Hank Frankenberg Cinematographer
    Oct 13, 1998
    2,573
    My two cents: I've built lots of speakers and have settled on simple butt joints, no screws (big waste of time and effort). Dowels, biscuits, and certainly mortise and tenon joinery are all unnecessary, IMHO. I recently built these 250lb+ towers for GR Research with butt joints. Okay, I admit to using eight screws in a section of one joint because I didn't get glue squeeze-out there :b
    http://www.geocities.com/hankbond1/My_page.html
  13. Jack Gilvey
    Jack Gilvey Producer
    Mar 13, 1999
    4,948
    Butt joints and Gorilla glue for me...simple and strong.
  14. Brian Bunge
    Sep 11, 2000
    3,716
    We use a cordless nailer, but only to speed up the process since we are usually building several enclosures at a time. It's nice to be able to assemble the enclosure and then head straight to the router table in a matter of minutes!
    Brian
  15. Pete Mazz
    Pete Mazz Supporting Actor
    May 17, 2000
    761
    Brian, any unexpected sparks flying yet? [​IMG]
    Pete
  16. Rob Lloyd
    Mar 22, 2001
    234
    I haven't seen any sparks from the nails yet. I think (hope) the nails are too soft to do much harm to the bits if you do hit one. At least they haven't nicked the carbide yet.
  17. Brian Bunge
    Sep 11, 2000
    3,716
    Pete,
    Since we round over the vertical edges we normally just nail the baffle and backs at the top and bottom. This with plenty of Titebond glue seems to work fine. My dad did forget one of his sub enclosures and put nails all the way around the front of the enclosure. The 3/4" roundover bit hardly noticed that the nails were there!
    Brian
  18. Brian Fellmeth
    Jul 30, 2000
    789
    Butt joints have one huge advantage over mitered that no one has mentioned. With miter joints, the panels have to be PERFECTLY sized. With butt joints, there is the option of making all the outside edges overhang a little large then use a flush trim bit to take the overhang off. Perfect box without precision cutting.
  19. David A. Frattaroli
    David A. Frattaroli Stunt Coordinator
    May 10, 1999
    173
    I used rabet joints when making mine. Dadoes inside for the braces.
  20. Jack Gilvey
    Mar 13, 1999
    4,948
