"Bow-tie" effect on Mitsubishi RPTV
Discussion in 'Displays' started by David_K_09, Jun 19, 2006.
  1. David_K_09
    David_K_09 Auditioning
    Oct 22, 2003
    7
    Our 4 year old Mitsubishi 55" RPTV has started having a bow tie or hourglass type distortion of the picture when the unit is first turned on. The center of the screen bows inward and the colors distort. It usually corrects itself after warming up, but sometimes it only "snaps" back in place if you tap the top of the cabinet.
    Any ideas on what the cause of this may be?
  2. Matt_A
    Matt_A Stunt Coordinator
    Jan 31, 2000
    90
    The convergence IC's are going kaput on it. You can either solder in new ones yourself or have an authorized service center fix it. Guess which one costs more. [​IMG]
    If you do a search on google, you'll find lots of different threads on forums all over the place talking about it. Apparently, it's quite common. Mine just started doing the same thing about a month ago.
  3. Gregg Loewen
    Gregg Loewen Video Standards Instructor, THX Ltd.
    Insider
    Nov 9, 1999
    6,373
    32
    New England
    Gregg Loewen
    hi guys
    This isnt that big of a deal...but it is very well known issues on crt RPTVs, especially the Mits.
    A service center should be contacted. the repair can be done in your home...and figure 200-275 as the cost.
    regards
    Gregg
  4. Dave H
    Dave H Producer
    Aug 13, 2000
    5,540
    177
    Does replacing the convergence IC's mean a new calibration is required?
  5. Matt_A
    Jan 31, 2000
    90
    The funny thing about my whole convergence problem is that I purchased a 5 year extended warranty on the TV. It is now 5 years and 1 month old. [​IMG] It just figures. The company that uses the contracts basically told me to go away. I'm upset, but what can you do?
