Bob U
- Oct 6, 2001
Thanks, Bruce. I'm off to go read about Servo 15's
-=Bob=-
-=Bob=-
You can be sure there will at least be a graph of the non-BFD'd room the day UPS shows up. I think I am going to EQ each SVS on a separate channel of the BFD
Although, you may not be able to get the coat hanger smile off your face long enough to get down to business..
I would probably run each from its own BFD channel as you say, but I would start out in "couple" mode in the likelyhood that they'll EQ very similar. Then you could de-couple later and individually tweak if you thought it was needed..
brucek
This device is a processor, (although dedicated) like any other, and can "hang up" when executing its start up sequence. Ever have Windows hang up your computer?
Sure, but I don't have Windows connected to the input of a power amplifier And if it hangs at full output, this is a major problem!
The BFD is connected to a Monster HT2500 power conditioner, so it should not have seen a spike, just turn off and on.
I'll post when I hear back from Behringer.
-=Bob=-
Well, they're here and unpacked and roughly setup.
Surprised they weren't double boxed, but although the outside cartons showed traces of UPS, the only damage was that one logo had fallen off. And they smell like a new car
BUT, although they sound better than my Sunfires, they don't sound anything like they did at Brian Fellmeth's house. I'm balanced at 75dB front and rears and 78dB on the subs. In phase reads 1dB higher than out of phase. I have NOT yet measured nor inserted the BFD. There is no room pressure as there was at Brian's.
I'm going to email Tom as soon as I finish this post then continue the discussion over here:
Bought my BFD Thread
More soon.
-=Bob=-
So, do these need a bit of break-in? Is my room just that bad for bottom end? Any thoughts?
