Mike Carter
- Dec 19, 2003
Hi, anyone have a real good handle on the Denon 5900 uni-DVD player? I bought one and just received it yesterday. The build date is August 2003 though which seems odd. Were there any updates after this build date I should be concerned with? I will be hooking it up to a Sim 2 HT 300 Link DLP projector ISF calibrated in a few weeks when I move into my new home but for the time being I will be looking at it on a BenQ 8700+. I read the owners manual and am confused on a few things concerning set up. Since I will be useing the DVI input on the Sim2 for HD DirecTV and do not have a DVI switcher yet I will use the Component outputs only for DVD.
What are some suggestions/tips with the picture settings in the 5900?
What does Progressive Mode Auto 1, 2 mean?
Any Picture Quality adjustment tips?
My DLP will be ISF'd so should these just stay at the Factory Default settings?
Set up Level 0IRE or 7.5 IRE?
I will be useing the new McIntosh MX135 pre-pro if that matters but plan on hooking up the 5900 video direct to the Sim2. Correct?
THANKS in Advance, Mike Carter
