boston vr975 versus nht 3.3
Discussion in 'Archived Threads 2001-2004' started by felix_suwarno, Dec 31, 2001.
  1. felix_suwarno
    felix_suwarno Screenwriter
    Dec 2, 2001
    1,523
    50 percent music, 25 videogames and 25 ht.
    which one do you guys recommend?
  2. Arthur S
    Arthur S Cinematographer
    Jul 2, 1999
    2,568
    The 3.3 is very deep and can present placement problems. The other potential problem with the 3.3 is that it is does not have a powered woofer like the Boston and for best performance you should have at least 200 watts per channel with the 3.3. Don't get me wrong, the 3.3 is a fine speaker but their size, shape, weight, placement needs and power needs are important considerations.
  3. Bob_A
    Bob_A Supporting Actor
    Jul 30, 2000
    876
    I agree...it depends on your amplification and preferences. Try to listen to both setups with the amplification you will be using at home. And make sure to give both speakers some room to breathe...particularly for their side-firing woofers. Good luck!
