Boston Sub or SVS?
Discussion in 'Speakers & Subwoofers' started by Jesse Sharrow, Dec 13, 2003.
  1. Jesse Sharrow
    Jesse Sharrow Supporting Actor
    Jul 11, 2003
    745
    I listen to mostly music. Should I go with a boston or an SVS? I know everyone raves about SVS, but are they as accurate as a boston?
  2. Phil A
    Phil A Producer
    Oct 1, 2000
    3,185
    44
    1,610
    Central FL
    Phil
    What does the system consist of as far as electronics (how will the sub be hooked-up) and speakers and what is the room like? SVS of course sells consumer direct so price-wise it's likely to be a better value than many things out there. Any speaker or sub is dependend on the way one uses it with what, the room, the type of music you like. I've only heard one Boston sub ($500 list one) in a setting other than a store that I could really evaluate it and it was pretty good for home theater in a smallish room and not the most music friendly in the world that I've heard. So I guess it depends on the model as well as both Boston and SVS have lots of choices.
  3. Robb Roy
    Robb Roy Supporting Actor
    Jul 15, 2002
    711
    Jesse,
    I'm a big fan of Boston's speakers (especially their VR-M line), and a former owner of their PV1000 subwoofer. I went with an SVS 20-39PC+. If you care, I was so impressed with the 20-39 I wrote a piece on the upgrade process: http://www.robbroy.net/HT/SVSReview.cfm.
    -Robb
  4. Tony Genovese
    Tony Genovese Supporting Actor
    Oct 5, 2000
    811
    No question: SVS. The PV1000 is a nice sub, but it isn't up to the task of home theater in any but the smallest rooms. There's just so much output you can get from a 10" woofer in a small cabinet. It's about the physics.
  5. Jesse Sharrow
    Jul 11, 2003
    745
    Well I want a VERY VERY musical sub for music. Very accurate for music. I dont want a sloppy sub. But when I play movies I want it also to be accurate but I want it to be relativly loud but not too crazy. But most importantly I want it to be accurate. I will be listening mostly to music.
  6. Chip E
    Chip E Screenwriter
    Nov 25, 2000
    1,165
    I didn't think there was any such animal.. "musical sub". I want a flat response with minimal distortion in a sub hence, sounds great with music & movies. I run an SV PB2+
  7. steve nn
    steve nn Cinematographer
    Jan 12, 2002
    2,418
    SVS does not make a sloppy sub. In those rare occasions that I do listen to music I just pull the calibration back on the receiver side. Very tight and accurate I assure you and thats with three 25-31CS+'s running. This is a calculated misconception that has been put out there by a few generally speaking. 99.9% of all SVS users will vouch for their accuracy and many have much/extensive experience with other brands.
  8. Chu Gai
    Chu Gai Lead Actor
    Jun 29, 2001
    7,270
    The SVS is a fine sub that's been quite favorably reviewed and the company has been extraordinarily responsive in dealing with customer issues even when the customer or other sources is clearly at fault. That said, in your quest for accuracy etc. what do you plan on doing about the room and speaker placements in order to arrive at this accuracy? Certainly a room can take the best of equipment and render it rather horrific, no?
    BTW, I don't own one but these are clearly bright people designing their equipment at very competitive price points.
  9. Paul_Ptaaty
    Paul_Ptaaty Stunt Coordinator
    Oct 16, 2003
    77
    Chu is right on,
    SVS is very accurate and musical. A far bigger concern that which sub is more musical will be fixing your room and EQing to get a flat response.
    Un eq'ed bass (assuming you don't have flat response from placement, using two+ )will sound boomy, but when you have a flat response, the bass will tighten up and sound much more musical and clean.
  10. Leigh_M
    Leigh_M Stunt Coordinator
    Feb 15, 2003
    152
    I have the Boston PV600 on my mainly music system. The sub is very smooth and accurate. My wife, who is a music teacher, is very happy with this set-up for all types of music.
    Also, for HT, it has more than enough power to shake everything on the shelves of my 15x22 room and I don't turn it up past mid way.
    Never listened to the SVS, so I can't comment there.
