John_Bilbrey
- Jan 16, 2002
Someone mentioned before that they noticed with their Boston CRC center that it would cause some interference on the TV when played at high volumes. Well, last night during some sub repositioning I noticed the same thing. I was using an old "Food for Woofers" disk to check the sound of the new location. Anyway, what I noticed was what can best be described as the same thing you get when you touch an LCD screen with your finger....kind of a puddling effect of like a dark purple color. Aren't centers supposed to be shielded? The CRC is positioned directly on top of my 32" Sony (circa 1996 vintage), with 12ga. wire running to it. The speaker wire runs down the back side of the TV...could this cause the problem or is it the speaker itself? The volume was up quite a bit louder than normal listening level (I was playing around an no one else was home, hehe). Could this cause permanent damage to the TV? Thanks!
