Bose problem i need help with
Discussion in 'Archived Threads 2001-2004' started by Anthony Moore, Dec 9, 2001.
  1. Anthony Moore
    Anthony Moore Supporting Actor
    Jul 12, 2001
    707
    ok, my parents are stuck with Bose. they like it, i dont care...fine with me
    BUT, i want to get them some Bass Shakers. They came over to my house and liked mine, so i want to get them some for x-mas.
    here's the problem:
    The technics receiver does their decoding and you have to turn the sub-out off because the Bose bass module does the crossover work.
    So there are 5 rca's goin from the technics to the Bose module.
    Now, usually when you hook up bass shakers you go with the subwoofer passthrough on the sub, OR you do a Y-Adapter from the sub-out on the receiver. But thats not turned on. And if i did turn it on and run the bass shakers from them, then no bass would be goin to the Bose module. So what do i do???????
    anyone?
  2. Anthony Moore
    Jul 12, 2001
    707
    and i cant really afford to buy them a seperate subwoofer
