Bose/For First Timer- Digital or Analog SPL Meter-Which is Easier/SVS
Discussion in 'Speakers & Subwoofers' started by James Edward, Jul 16, 2003.
  1. James Edward
    James Edward Supporting Actor
    May 1, 2000
    855
    For someone not familiar with the level setting process, which do you think would be easier- the analog or digital meter from RS?
    I'm assisting someone long distance, and they will be getting one meter or the other, depending on which is easier... I had set everything up in January, but new speakers and a problem with his Rotel 1065 receiver necessitates it being done again.
    Thanks...
    I should add that although he likes his HT setup, he'll probably do this once or twice, not ongoing like HTF members.
  2. NateF
    NateF Stunt Coordinator
    Aug 22, 2001
    63
    Get the digital meter. There's nothing as easy as ready "84" on the meter. It's really very easy to use.
    -Nate
  3. Jeff Gatie
    Jeff Gatie Lead Actor
    Aug 19, 2002
    6,531
    15
    Most people consider the analog more useful becaause you can watch the swing of the needle which is more descriptive of the swing in Db's than just numbers going up or down. But the digital may be more useful for the neophyte for the reason stated above by NateF above.
    The analog is definately more useful when doing bass sweeps or taming room peaks.
  4. James Edward
    May 1, 2000
    855
    Thanks. He's going to use it strictly for channel levels. I'll have him get the digital.
  5. Richard Little
    Richard Little Stunt Coordinator
    Jun 20, 2003
    105
    the analog is on sale right now if they are like me and really get a kick on saving $10.
