Bose AM16 question
Discussion in 'Speakers' started by Matt Weldy, Jul 16, 2004.
  1. Matt Weldy
    Matt Weldy Second Unit
    Feb 4, 2002
    335
    I set up a theater in a new construction house for a friend ( I tried to talk him out of bose ) However I pre ran all the wiring and now I am going to install the speaker. I saw in the manual that there was a "module input cable adaptor for existing wiring" I was wondering if I really need that or not? I have the existing one that came with the bose. Should I just wire tie the speaker wire that goes from the amp to the module (sub). And if so what would be the best way soder.... I already put new rca plugs on the wire I ran in the wall. So one half is taken care of. I just know I wouldnt want any breaks in my speaker wire. Or will one break affect the speaker quality. Not that I should use bose and quality in one sentence.
  2. Kenneth Harden
    Kenneth Harden Screenwriter
    May 13, 2002
    1,365
    You mean to adapt the exsisting speaker wire (that you ran) into the RCA plugs that go into the 'bass' (and I use that term lightly) module? If so, just make it work, it's not a big deal.
  3. Matt Weldy
    Feb 4, 2002
    335
    no I mean the wire harness from the module to the reciever. I ran those wires in the wall also.
  4. JoanPablo_T
    JoanPablo_T Stunt Coordinator
    Mar 21, 2001
    173
    call bose tech support. 800-367-4008. they can send out the adapters for you. So you don't have to crimp.
    JP
    [​IMG]
