Bose Acoustimass Woofer Humming (1 Viewer)
Ab82353
Al
Hello, my Bose Acoustimass is connected to my TV through RCA cables and is making a buzzing humming noise. How can I fix this?
My TV is a RCA 42" ultra slim
Wayne A. Pflughaupt
Corpus Christi, TX
Wayne
Make sure it’s plugged into the same electrical outlet as the TV.
Try changing the RCA cables.
If it has a grounded plug try a ground lift adapter. If that makes a difference, you have a ground lift, probably caused by a CATV or satellite feed.
If none of this makes a difference, the sub probably has issues.
Wayne A. Pflughaupt
andriesprice
