boosting below tuneing freq.?
Discussion in 'Home Theater Projects' started by PatrickMiller, Feb 28, 2004.
  1. PatrickMiller
    Dec 29, 2003
    35
    Im assuming I shouldnt boost the frequencies below the tuning of my ported sub as tempted as I am? My sub goes to about 34Hz (+/-3dB).
  2. Bob Kavanaugh
    Bob Kavanaugh Second Unit
    Jan 17, 2003
    282
    It's a good way to unload and possibly damage your driver.
  3. PatrickMiller
    Dec 29, 2003
    35
    If my subs response is 34-150(+/-3dB)is 34 the tuneing of my port?
  4. AndersP
    AndersP Stunt Coordinator
    May 17, 2002
    53
    I think it´s more like 40 Hz, but it´s impossible to know without some measurements.
    Take down some bass test signals from the net with like 1 Hz increments in the area 30 - 50 Hz and burn a test CD.
    Get a RS sound level meter and measure very close to the speaker cone at low level without touching it with the mike.
    The frequency with the absolute lowest output is the tuning frequency. At this frequency you can also feel the "wind" from the reflex tube at its strongest.
  5. Dustin B
    Dustin B Producer
    Mar 10, 2001
    3,126
    Another less accurate, but easier way to get a decent approximation of the tuning frequency would be to provide us with the outer dimensions of your sub (excluding any feet or grilles), the diameter and length of the port, whether the port is flared or not and how much the sub weighs (so we can guess wall thickness). Then one of us or you can use LspCAD or UniBox to model the enclosure's tuning frequency.
  6. PatrickMiller
    Dec 29, 2003
    35
    Well I already have a meter and have measured down to 20Hz.
    There is some output there but it cant be tuned that low, so how can the frequency with the least output be it?
    It is an Infinity 10" Entra 150w. 14.5"x16"x15".Port is flared from what seems to be 2" to 4" and 11" long.Weight is
    47lbs. Thanks!
  7. Dustin B
    Dustin B Producer
    Mar 10, 2001
    3,126
    From that I'm guesstimating a net internal volume of 40L, with a 2" port that is effectively 10" long it works out to a ~22hz tune.
