Boomy bass problem from rear wall
Discussion in 'Archived Threads 2001-2004' started by Joe Bauman, Feb 24, 2002.
  1. Joe Bauman
    Joe Bauman Stunt Coordinator
    Jan 1, 2002
    52
    It appears the the rear wall behind the listening postiion is producing a boomy bass. I intially moved my speakers (two hannel stereo) around trying to fix the problem but no matter where I put them, the boomy bass was still there. Finally I realized that if I moved my listen position away from the rear wall behind me, the boomyness dissappeared. So, I moved the couch 2 feet away from the rear wall and it sounds better but some boomyness is still there. I really need to move the couch out an additional 2 more feet but that is not possible.
    Any ideas on how I can stop this? Thanks.
    (originally posted in the speaker forum but may be more appropriate here.)
  2. Wayne A. Pflughaupt
    Aug 5, 1999
    6,207
    56
    9,110
    Katy, TX
    Wayne
    Joe,
    Low frequencies seem to “chase” boundaries. If you had a sub, I’d say turn it down if your seat is against the wall. Since it looks like you don’t have a sub, then all you can do is turn down the bass control, or move your seat further away from the wall.
    Wayne A. Pflughaupt
